200 gallon tanks
Discussion in 'Questions From New Drivers' started by Mcg0958, Aug 12, 2018.
  1. Mcg0958
    Mcg0958 Bobtail Member
    13
    15
    Jul 30, 2018
    recently I was running on fumes. I was getting a bit worried. So i finally reached my fuel stop and filled up. The 200 gallon tanks only took about 137 gallons. I’m I to assume there’s over 60 gallons when the low fuel light comes on?
  3. WesternPlains
    6,274
    51,411
    Sep 1, 2017
    The tank will have it engraved on it what it’s max actually is.
    I wouldn’t be surprised if you’re right. They try to make warnings so millennial that you’ll never run out.
    Lepton1 and Zeviander Thank this.
  4. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,738
    Mar 19, 2018
    Nashville
    At 1/4 tank my Volvo will take 150 or so. At 1/8 I have put in 180.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Did you verify that both tanks took the same amount... many trucks will suck more from one than the other sometimes .. AkA drivers side with the gauge takes 80 gal and passengers side 57 gal hence the low fuel warning
  6. Kyle G.
    Kyle G. Road Train Member
    3,754
    19,604
    Jan 23, 2016
    Eastern Iowa
    I have a single 150 gallon tank. My low fuel light comes on at about 60 gallons. I once ran it down to E and barely squeezed 130 into it.
  7. Ridgeline
    22,101
    113,192
    You guys need to know that the sending unit has a limited amount of swing on the sensor, it will only go so far down when the level drops and no farther. Once it hits the low end then it shows empty. They don't use special sensors for large tanks, it is pretty much the same one for all.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Cut a clean stick, no splinters or material coming off it. Dip the tanks. You should come up with a certain height of liquid. In the old days that was what we did to determine if it is low or out.
    200 gallons is stingy. I prefer 300 and over in two tanks. I'll tell you why. ATS gave me a tractor with a single 140 gallon tank and it required me to fill twice if not more daily to do OTR. I had more episodes of running out to where both fuel is out, hours is out and sit until next midnight to get more fuel. I got plumb sick of that.
    The most Generous was FFE. We were a team and I think 320 gallons useable out of 335 or so in two tanks. Burn through that in 24 to 30 hours roughly, fill em. If we are good and the winds are with us, we got 1700 miles out of it give or take a percentage depending on the terrain situation somewhere criss crossing the USA. I think roughly in 2001 we burned 85000 dollars worth of fuel that year. I sure hope and think FFE made their money to pay that bill.
    I am probably the last of my kind, big sloppy 35 gallon tank in a great fat barge pulling up to a .28 cent per leaded gallon gasoline station (With spilled fuel in puddles to roll through no less...) and watch relative pay a dollar for the weekend because he could not be bothered to fill it until Sunday night for the work week.
    During the odd even days my father's Datsun took 5 dollars to fill I think about 10+ gallons and it's good all week and then some while everyone else begged gas during the arab oil embargo.
    I have a 25 gallon tank and deliberately keep the fuel somewhat short against theft and literally do not fill it but once every 19 t0 24 months on a hundred dollar bill and a hatful of stabil additive.
    Your fuel is not low until you are on enough a incline to pile the fuel in the bottom of the tank on the end where the feed intake to the engine is not. (That's where your stick comes in) Remember you can always call out a fuel dealer locally to deliver fuel to you either on your own cash, credit or company card if they recognize it. Never allow it to run out. It causes no end of problems.
  9. bigkev1115
    bigkev1115 Road Train Member
    2,363
    3,609
    Oct 23, 2009
    Alexandria, AL
    Some of the Cascadia fuel gauges are about a 1/4 of a tank off what the needle is showing. If needle is showing 1/4 tank, it actually has closer to a 1/2 tank. I drive a 2018 old body style Cascadia. Now Volvos on the other hand are accurate with the fuel gauge
  10. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,600
    Oct 6, 2009
    Colorado
    you know how i can tell you drive a Cascadia?
    cuz they all do that. it's ridiculous. it's so inaccurate it's useless
    just reset your trip odometer every time you fuel and fuel up about every 1000 miles. unless you are ridiculously heavy there's no way you get less than 5mpg and won't run out of fuel.
  11. Long FLD
    Long FLD Road Train Member
    11,354
    45,709
    Mar 4, 2015
    Next time your fuel warning comes on stick the tanks and see how much is left. I run dual 90’s and when my light comes on the most I’ve ever put in was 145 gallon. But my caps are up under the bunk so I have no way of sticking them or shining a light into them.
    SingingWolf and Lepton1 Thank this.
  12. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Don't forget there is a large portion that is unusable in your tanks.... True empty is when you start sucking air... Then bad things happen
    Farmerbob1 Thanks this.
