2.79 Rears :/
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jerzey, Jun 19, 2016.
  1. Jerzey
    Jerzey Bobtail Member
    15
    Jun 19, 2016
    Hello fellow logistic specialists
    I had a 2004 Freightliner Columbia. It has a Detroit 12.7 (complete inframe Feb 2015...less than 100k on inframe). It has an Eaton Fuller 10.
    Here is my dilemma...
    I've replaced a lot of parts along the way. But I'm faced with wanting to sell it due to a lack of pulling power when facing hills/mountains. Before I make a rash decision, I would like to know what my options are as far as replacing/rebuilding the rears and pricing associated with it.
    Thanks in advance ;)
  3. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Call truck pro. I just picked up 3.55 rears for my w900. Both for 4000.00 . Pain that they wanted old befor getting new. Fore the core. Then I put all new bears in wheels and out put shaft. In short spend few bucks now save tons later. But I have a barn to complete task.
  4. Jerzey
    15
    Jun 19, 2016
    Great to know! Thanks so much ;)
  5. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    What's the drive ratio of your transmission? If you're running a direct drive, switching to 3.55s is going to be closer to running 4.88s with an OD transmission than what you're expecting. Also, what size tires are you running? You need to factor all of that in to figure out where you're going to be at for cruising speed. To that end, swapping tire sizes might be a more economical way to get you to where you want to be vs. swapping out rears.
    There's a formula for figuring it all out...
    (##60)/(B*C*D)
    A = engine RPMs
    B = Rear end gear ratio
    C = Transmission final drive ratio
    D = Tire revolutions per mile
    So if you're running a direct drive transmission now with those 2.79s and we'll say tires which give you 513 revolutions per mile, and you wanted to see where you were at 1500 RPMS...
    (1500*60)/(2.79*1*513) = 62.88....
    So you'd be running between 62 and 63 MPH at those RPMS. Change it up to 3.55s...
    (1500*60)/(3.55*1*513) = 41.419.....
    See the difference? Knowing your transmission drive ratio and tire revs per mile is important. The guy running 3.55s probably isn't using the same transmission as the guy running 2.64s or 2.79s.
  6. Jerzey
    15
    Jun 19, 2016
    Thanks for the reply!
    How do I figure out my transmission drive ratio? I'm running 295/75/22.5 low profile. I'm just at 1500rpm at 65mph.
  7. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Sounds like a direct. Find the model number and call a dealer.
  8. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    On the right side of the dash, in front of the passenger seat, there's a panel you can remove and you should be able to see a spec sheet once you do... it will include the nomenclature of the transmission (e.g., RTLO16909A, FRO16210C, etc.), and you can determine it from that.
  9. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Get ahold of rebel127. Leave 2.79 w direct Trans get his ecm tuning with 171702 Borg Warner turbo. You will love it
