1st time Houston to Bakersfield .ca advice ?
Discussion in 'Experienced Truckers' Advice' started by frmtxsu, Aug 16, 2019.
  1. frmtxsu
    frmtxsu Light Load Member
    87
    45
    Apr 29, 2019
    Houston, TX
    First time traveling from Houston to Bakersfield California pulling a tanker any advice question ways not to go? Routes? Ways to go or things to avoid thanks in advance
  3. Espressolane
    16,975
    102,317
    Just depends on what you want.
    Mostly 1-10 to SoCal, then 5 north.
    If you want to come in the back side, need to get over to Barstow and the 58. Could use 95 or 93 up to 40 to make that happen.
    tscottme and rabbiporkchop Thank this.
  4. frmtxsu
    87
    45
    Apr 29, 2019
    Houston, TX
    I was thinking the back route as you said by like Barstow to avoid all the traffic in La I just don't know how treacherous that route is coming through the mountains or other problems are headaches with it plus trying to find a truck stop somewhere along the way
  5. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    First things first, Do you have a CARB compliant truck ?
  6. frmtxsu
    87
    45
    Apr 29, 2019
    Houston, TX
    Yes thank you for asking I work for a large responsible company
    Diesel Dave Thanks this.
  7. frmtxsu
    87
    45
    Apr 29, 2019
    Houston, TX
    I'm pulling in open bore tank so I'm thinking more so like for example there's more truck stops in this particular area or this area is really dangerous or go this way it's easier Drive stuff like that as far as my legality or condition of truck all that stuff is good
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Head up to 40 either way you want to and head west. I would never go on 10. check the miles, I bet 10 would run you at least a couple of hundred out of route, even if it was a decent way to go.
    88228822 and rabbiporkchop Thank this.
  9. frmtxsu
    87
    45
    Apr 29, 2019
    Houston, TX
    Okay I will check that out that sounds like good advice and thank you
  10. Espressolane
    16,975
    102,317
    You should have no problems. Run it all the time.
    Plenty of places to stop / fuel along the routes.
    If you decide to run 93 or 95, just be sure to have around 3/4 tanks before heading off.
    tscottme Thanks this.
  11. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Where about in LA area you delivering ? If your coming from Houston, why not just shoot straight out I-10 ? The last truck stop before getting into LA would be in Ontario which is where I-15 and I-10 meet up. After that, it’s about 1 hour or so into LA area, depends what time of day you need to be in .
