i would like to put a 180 thermostat in my 2ws cat motor, would anybody please tell me if this is a good idea or not? I recently had it turned up to a 550/1850 with 6999 codes and fuel temp wire. runs awesome but the temp stays at 190 all day till I hit a hill and then it climbs up to 200-210.I usually just kick the fan on when it starts to reach 200 and it won't go any higher. my fan sensor does'nt kick in till around 210. I have never really been to concerned with my temperature before I turned it up,but now I just get a little paranoid when I see the temps start to climb.I am sure i have 195 themostats in there as this is the temp it has always run at since I got the truck It is a 2000 intl. 9400I .I know the radiator is good and has good airflow but am not sure if is big enough to handle the extra power.I can deal with the temps now just wish to know if a 180 will help. thanks....joe
180 or 195 thermostat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joey83854, Apr 13, 2009.
Sounds like normal operation to me. try letting the fan come on by itself at 210. it should pull down under 200 and shut off. if temp dosent come down,then you have a concern. the ecm protects against high water temp. should derate around 230. IMO, your not making enough power to exceed the limits of a properly operating cooling system. I dont think you should be concerned.
kick in the fan at 200 ok cat r great engines but they r a head case so be on the safe side and it wont hurt ok 200turn it on , am in jamaica and we put in a pair of 175s just to be sure
Just spoke to a very knowledgeble Cat mechanic today about the same problem. If I run my truck at fast idle while in the sleeper, temp will climb to around 208, then eventually engine fan will kick on. Turning the engine fan on manual, or simply turning the A/C on will keep the temp around 182 on my gauge. Maybe my radiator needs to be "blown out". For peace of mind, I ran the fan on manual couple of months back in Chicago when they got about 3" of snow and freezing rain, because the water temp wanted to stay around 208.
The mechanic I spoke to said that the sensor tells the fan to come on around 210, (don't remember the exact #), and he was fairly sure that there was none available that would kick the fan on at a lower temp, like 200. He commented that he is often questioned about that, with our Louisiana summers being so hot.
joey83854
Just wondering, do you have any problems with your EGTs when your water temps rise while climbing a hill? -
Your fan will come on a 217f coolant temperature ( 3406e c15). 207 on older and c12. You will find your international is hard to keep cool. I have one with 700 to the ground and its way harder to keep cool compared to a Pete. Just the size and design of the rad. I would keep turning on the fan at 200. I think Cat just wants to sell more head gaskets and heads with that high of fan turn on temperature. I have run the 180 t stat on higher hp builds, it gives you a bit more time before it heats up. Your stock reg is 192.
thanks everyone for your replies, droy,yes i have to watch my egts as the temps climb.when i am running with a load on (haul manufactured homes)I have a running partner that i let lead on the other half of the home cuz he has a crappy 11.1 detroit and i don't want to run away from him. I usually come up onhim pretty quickly on hills so while i am following behind him is when my egt's climb.I never have seen it over about 1050-1100.I will start downshifting to get it back down and kick on my fan. When i am running aloneI can usually nail it at the bottom of a grade and hold top gear(13)a long time before my temps climb. Running loaded down the road my egts usually run around 800-900 and water temps 190
droy Thanks this. -
DDS.I would like to know the combination that you put together to get 700 to the ground on that intl.I don't really know how much i have right now,guessing maybe 525 or so to the ground.since getting on this site and others I have become a HP #####!When money and time allows I am going to install a B model manifold and bigger non w/g turbo which i would assume lower both my temps and give me more POWER!And better fuel mileage So would you recommend a180 thermostat then? thanks ,joe
IMO put on a coated manifold from PDI,full tilt,Pittsburgh would be a better option with your stock turbo and some ECM changes it should make good hp. -
Out west in Aus a lot of guy put in lower temp thermostats because of the high ambient temps, interestingly if you do this but dont change the fan turn on temp you get a small gain in fuel economy because the fan is not on so much, comes on later on a pull.
If you want the fan to turn on earlier you fit a horton switch from a mechanical engine and simply run the fan solenoid wire through the switch and back to the solenoid. These switched come in a range of temps. Fit the switch to a unused hole in the thermostat housing. If you do this it will not take away the ECMs ability to control the fan, so it will still work with the A/C, jakes, PTO, etc. it will simply come on earlier when it gets hot.mtoo, joey83854, droy and 1 other person Thank this.
