17.5 trailer tire
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nvtanker, Sep 13, 2020.
  1. Nvtanker
    Nvtanker Bobtail Member
    What have yall found to be the easiest way to dismount a 17.5 trailer tire with tire bars
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Look at the hump in the center of the wheel. Remove and install the tire from the side that the center bead recess is closest too. This is the center groove the bead falls in when removing the tire. This may look backword as most 22.5 come off easiest from the open side up.
    Changed plenty of 17.5 with spoons, taking them off the wrong side will definitely fight you. Dish soap and water coming off. Lube the beads going on.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    We use one of these @ work. Pricey, but work excellent.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Way cool man!
    spsauerland Thanks this.
  6. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    I use an old coats40-40A tire machine in my shop.
    I can dismount and mount a continental 17.5 in less than ten minutes.
    Totally agree with @Goodysnap it is easiest to find the center Indent of the rim that is closest to the bead and peel it off that side.
    On my car trailer rims it happens to be the bead opposite of the valve stem side.
    Goodysnap, spsauerland and BoxCarKidd Thank this.
