I want to give a congrats to Doodle for making 1637 RWHP with his work truck....it took a while to get there...a few broken parts along the way....but in typical Doodle fashion...fix it and try again! SO CONGRATULATIONS! Worked regular and if you know him he runs the H*** out of it.....straight diesel...no special fuels.....and No special ecm programming....
RW
1637 rwhp work truck
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ROBSREDFORD, May 26, 2012.
Congrats Doodle!!!!Where did he dyno at? At Antrim he lost his low pressure turbo.
Leon- He took it back to Antrim...took it home ...fixed it....worked it...the brought it back up yesterday.. They replaced LP with different one and played with wastegate on HP most of day.....gonna try dif housing on LP next
Impressive!
Who is doodle? What kind of truck does he have? What engine does he have? Great to hear but very vague post.
Doodle is..........Doodle Blizzard from Pikesville NC. The truck is a 389 Peterbilt glider with a 63" flattop sleep with a C-16 CAT engine. The engine has modified 800 Hp marine injectors with a 1000 Hp marine camshaft. The turbos are a BW 600 OEM replacement as the high pressure with the wastegate modified to open early. The low pressure is a Holset HX80 G shaft
Tom'o, kwcat and Buckshot7cz Thank this. -
Doodle is a trip to talk to! I'd like to meet him and Kurt one of these days. Between the two of them there is a lot of HP knowledge and I'm sure even more BS...LOL
......in fact I've taken those injectors apart with my own hands
BS...........What is BS??????? -
Just ask your wife, I'm sure she'll tell you your full of it...LOL.
Jfaulk99 Thanks this. -
sounds like hes sunk alot of money into the motor. the cam and injectors cant be cheap to go that route
