16 hour short haul exemption
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Fordmechanic, Feb 17, 2021.
  1. Fordmechanic
    Fordmechanic Light Load Member
    53
    13
    Apr 15, 2015
    Lancaster, NY
    If I need to use a 16 to get home ... am I still legal to do a 2 & 8 SPLIT? Or must I take a full 10?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    If you are doing a split you are likely not not eligible for the short haul extension because you didn't stop at the same location for the last 5 days.....
    It requires the following conditions.
    1. Not used since the last reset or 6 days.
    2. The last 5 days have to be stopped in the same location. *No not the yard up the street vs. the shop, but the same location.)
    3. The regs actually specifically state a 10 hour break is required, but only before the 16 hour exemption.
    Here is the wording of the regs.
    (o) Property-carrying driver. A property-carrying driver is exempt from the requirements of §395.3(a)(2) if:
    (1) The driver has returned to the driver's normal work reporting location and the carrier released the driver from duty at that location for the previous five duty tours the driver has worked;
    (2) The driver has returned to the normal work reporting location and the carrier releases the driver from duty within 16 hours after coming on duty following 10 consecutive hours off duty; and
    (3) The driver has not taken this exemption within the previous 6 consecutive days, except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by §395.3(c).
    brian991219 and sevenmph Thank this.
  4. Pepper24
    Pepper24 Road Train Member
    2,048
    1,558
    Dec 3, 2010
    If you lay over one night in the week you can’t use the 16 hour rule
  5. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    No. You would have to had started and returned to the same location, on your 5 previous shifts.
    FMCSA Regulation 395.1 Sub section O Parts 1, 2 & 3
  6. Fordmechanic
    53
    13
    Apr 15, 2015
    Lancaster, NY
    Ok. I have been local and had a 34. Today i worked 15.5 hrs and took a 2hr break during that time. I didreturne to the yard. Can I log 8 hrs in sleeper and go? Or must i do 10?
  7. Pepper24
    2,048
    1,558
    Dec 3, 2010
    So if you had a layover one night you couldn’t have got back to your starting place right
  8. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Have you parked for your 10 hour break break in the same location for the last 5 working days? Including today?
  9. againstthewind
    againstthewind Road Train Member
    2,027
    3,164
    Oct 26, 2012
    i say this all the time with threads like this but all this math and figuring out regulations sounds more tiring than just driving the #### truck, but i get it, keeping people in busyness is the best way to control a society. lol
  10. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    I guess it's too late, but, no you can't take only 8 hrs. , You have to to take 10. 8/2 splits are only for otr drivers.
  11. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    This is 100% factually wrong.
    Oh, it's most useful for OTR drivers, but there is nothing in the regs that state as such. I can see scenarios where it would be useful to "local" truckers. At least local truckers that log legally as in actually in the sleeper and not off duty at home.
