16 hour rule??
Discussion in 'Questions From New Drivers' started by Calregon, Dec 30, 2014.
  1. Calregon
    Calregon Light Load Member
    170
    106
    Dec 8, 2013
    Oregon
    So.. I think... If I have started and stopped in the same place for the last 5 days and been within my 14, I can use a 16 hour rule (not exceeding 11 driving). I had the last 5 days off, so can i use my 16 today? I documented it in my log. I was stuck at shipper for 6.5 hours. bla bla bla.....
    If I am wrong on this and you would like to explain it, PLEASE try to make it easy to understand. Thanks for the input.
  3. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    What did you do the PREVIOUS 5 days prior to the 5 days off? The 5 days off count as a RESTART, so you have to go back TEN days.
    HotH2o Thanks this.
  4. Flybynight041
    Flybynight041 Medium Load Member
    358
    271
    Dec 9, 2014
    16 hour extension only applies to city and short haul drivers that start and end each day at their companies terminal. OTR drivers do not qualify for this extension.
    LGarrison Thanks this.
  5. DonRobbie
    DonRobbie Heavy Load Member
    916
    2,125
    Nov 26, 2005
    Midwest
    You have to be relieved of duty at the same place you started every day to use the 16. You can only use it once a week.
    Generally if it applies to you your company will have a pretty clear understanding of how it works.
  6. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Days off don't count as "duty tours". What you did before those 5 days is what determines if you're eligible for the 16 hour exemption. Like white dog said, you'd have to go back 10 days.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Local drivers get a 16hr day once a week if they meet criteria.
    The link is here: http://www.fmcsa.dot.gov/regulations/title49/part/395
    (o) Property-carrying driver. A property-carrying driver is exempt from the requirements of § 395.3(a)(2) if:
    (1) The driver has returned to the driver's normal work reporting location and the carrier released the driver from duty at that location for the previous five duty tours the driver has worked;
    (2) The driver has returned to the normal work reporting location and the carrier releases the driver from duty within 16 hours after coming on duty following 10 consecutive hours off duty; and
    (3) The driver has not taken this exemption within the previous 6 consecutive days, except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by § 395.3(c).
    So need the last 10 (or more) days to get the last 5 tours. You will also need to be starting and stopping at the same "normal" location. If you are dispatched to go to a dc and use that as your base, I'm not sure it would count to allow the 16. But, and I know it is late, you should call your safty department 'cause even if you are legal you could be violating company policy by taking the 16.
    -Steven
  8. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    If you stayed overnight anywhere other than your home base before your reset you cant use it.If you normally return to base everynight and return to base the same night on your 16 hr " short haul truckers exception" it works well. Still only 11 hrs driving though
  9. Calregon
    170
    106
    Dec 8, 2013
    Oregon
    Guess I'll be getting called in and have some explaining to do.
  10. Flybynight041
    358
    271
    Dec 9, 2014
    If you stay in the same city all day, you can log your driving on line 4.
