15 speed explanation
Discussion in 'Questions From New Drivers' started by 775mito, Jun 28, 2020.
  1. 775mito
    775mito Bobtail Member
    34
    37
    Jun 27, 2020
    Montana
    So far I've heard several ways 15 speed works. First I was told it was low for first 10 then high for the last 5, I was then told extra low 1-5 then normal lo/hi for 6-15, then a confusing 1-low low, 2 low low 3 low low 4 low low 5 low low 6 low hi and so on. It's for a belly dump sorry no image I can get one later though. Thanks
    Coffey Thanks this.
  3. AModelCat
    154,533
    Its essentially just a 10 speed with 5 "deep reduction" gears.
    Most cases you'd just run it like a 10 speed.
    The deep reduction gear ratios overlap low range so if shifting from lowest gear to highest, you'd only use 12 of the 15 gears.
    These would be the gear positions you'd hit with the gear shift if going lowest gear to highest gear:
    DR: 1-5
    LR: 4-5
    HR: 1-5
    dibstr, 650cat425, okiedokie and 6 others Thank this.
  4. Judge
    84,607
    Easiest way to shift 15
    650cat425 and 775mito Thank this.
  5. AModelCat
    154,533
    My truck has an RTO-15615 15 speed in it. If you look at the rebuild manual it actually applies to the 10 and 15 speed transmission of that design level. Main box is the same, only difference being 2 speed aux in the 10 speed vs 3 speed aux in the 15 speed.
    775mito Thanks this.
  6. MACK E-6
    48,131
    219,684
    When I drove one like that, it was 1-3 in DR, then back to 2 low.
    Another thing that’s important to mention is not to try and switch out of DR in gear. The truck won’t like that. You have to do that in neutral.
    650cat425, AModelCat and 775mito Thank this.
  7. 775mito
    34
    37
    Jun 27, 2020
    Montana
    THANK YOU!!
    Diamond Reo Thanks this.
  8. AModelCat
    154,533
    Yep you basically just drop one gear back in the main box when upshifting out of deep reduction to low range.
    650cat425, okiedokie and MACK E-6 Thank this.
  9. MACK E-6
    48,131
    219,684
    I did some heavy haul with them, one in an R model Mack and another in an International 9300.
    In the Mack the deep reduction switch was on the dash.
    650cat425 and Diamond Reo Thank this.
  10. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    The bag of #### 15 speed is similar to an 8LL just based on a ten speed, it has a tall low low and a short OD and a bunch of dog #### ratios in the middle, which is why they were canned for the 18. Your best bet is to start in deep reduction then shift to the regular low side in neutral as you go back a gear, i usually go 1-2-3 then back to 2, if it’s flat I go to neutral and go back to the same gear.
    don’t forget where the gears are if your driving different transmissions....
    that video is of a direct or has a new cover on it, the over drives shifted high gear
    Against the dash and 1:1 against the passenger seat
    The Veteran and 650cat425 Thank this.
  11. 77fib77
    77fib77 Road Train Member
    10,173
    62,823
    Jul 7, 2010
    St Louis
    I drove them in the oil field. Only in snow or rain I would use the DR. The clay would stick to everything and it wouldn't turn unless you turn using the Dr. Plus the spacing between all the gears is more even. In a 10 8,9,10 have a lot seperation between them , which I don't like.
