15 speed Eaton??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dedrick, Nov 20, 2019.
  1. Dedrick
    Dedrick Bobtail Member
    32
    16
    Aug 30, 2016
    I am buying a truck from a friend of mine who is kind of a doofus. Now, I watched him drive the truck and he does not grind his gears. But, he was calling it a 13 speed the whole time when after driving it across town I believe it to be a 15 speed.
    It appears to be a 10 speed with a H-L splitter that works for the high range gears (6-10).
    The way my friend would shift it was he would go straight from 5 to 7L, 7H, 8H, 9H, 10H. So I guess the way he used it it was a 13 speed because he was skipping over 6 all together. When downshifting, he would sometimes downshift to 6H on a curve. But he was calling that "extra gear" you can shift down to on a curve. But he said he never used 6L because the rpms were weird.
    I found what he was talking about because 6L appeared to be a lower gear than 5. I guess, that could be viewed as a gear you can shift down to in traffic without having to keep using the splitter to go back and forth from 5 to 6.
    I guess my question is, are the L gears meant to be used regularly that way? It seems when cruising along in 10H, 10L is a nice gear to have as a passing gear or uphill gear to maintain speed, rather than going down to 9. But is it meant to be used that way?
  3. 062
    062 Road Train Member
    6,416
    34,316
    Oct 20, 2013
    One way to tell a 13 from a 15 is the color of the thumb switch on the side. 13 is red,15 is blue,18 is gray.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,587
    9,955
    Mar 30, 2014
    If he drove it like a 13 speed, why would you think it is a 15? And btw, the extra 5 gears are Granny gears, not on the high side.
  5. AModelCat
    166,502
    A 13 is just a 9 that you can split the top 4 on. Red splitter button.
    A 15 is just a 10 that has 5 deep reduction gears. Blue button on the shifter, plunger on the side of the stick, or an air switch on the dash.
    If you progressively shift a 15 from lowest gear to highest gear you'd only use 12 gears.
    Oxbow, spsauerland, Bean Jr. and 3 others Thank this.
  6. wore out
    wore out Numbered Classic
    18,255
    231,360
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If he went from 5 to 7th it's a 13. A 9, 13 and 18 do not use what you call 6th or low position on the high side.
    Yes it's meant to be split that way.
    Oxbow, Bean Jr., exhausted379 and 2 others Thank this.
  7. Dedrick
    32
    16
    Aug 30, 2016
    Because he wasn't including 6L or 6H in his 13?
    Let's ask questions that have already been explained in the OP.
  8. Tall Mike
    Tall Mike Road Train Member
    8,231
    42,610
    Aug 20, 2014
    New York State
    Unless the splitter button has been changed.
    Chrome is a popular color is why I post this.
    Oxbow, exhausted379, 062 and 1 other person Thank this.
  9. AModelCat
    166,502
    How do you get a 6th position? They're only 5 speed main boxes.
    NVM. Brainfart
    Oxbow and Bean Jr. Thank this.
  10. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    I think your buddy probably has a 13 spd and uses the cheater gear, which is not recommended.
    You can't split gears with a 15 speed, you drive it like a 10 spd unless you need more low end grunt.
    What might look like the splitter is deep reduction for a 15 spd, the hi lo paddle is hi lo just like the other Eaton boxes.
    Oxbow, Bean Jr. and OLDSKOOLERnWV Thank this.
  11. OLDSKOOLERnWV
    20,011
    302,270
    I was wondering the same thing....
    We use to use “the cheater” just to finish topping a hill but never to pull the hill.
    Oxbow and exhausted379 Thank this.
