14 volts at the battery and alternator and 12 volts on the gage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sailboatjim, Sep 10, 2014.
  1. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    Just like the title says, I have 14 volts charging at the battery and alternator and 12 volts on the gage and fuse panel on the passenger side of the truck under the hood.
    This is a Peterbuilt 387 with ISX Cummins engine. Truck runs fine. Everything works fine.
    I heard this may be a personality/body module or something to that effect but I have no idea where that might be located.
    Anyone have any ideas? I was all set to have the alternator rebuilt until I went there with a voltmeter and did some checking around.
    The alternator is a delco remy 24SI
  3. Heavyd
    Heavyd Road Train Member
    7,748
    6,181
    Feb 4, 2009
    Most gauges in modern trucks are electronic and feed data from some kind of module. So if your gauge is reading low and you are measuring good voltage everywhere, chances are the module that reads data for that gauge is getting faulty power itself.
  4. sailboatjim
    292
    173
    Aug 27, 2014
    Boston, Mass
    Must be because the fuse panel that is on the outside passenger side firewall has 12 volts on it on every fuse but checking the voltage at the alternator and batteries shows a sold 14 volts.
    Wish I had an idea where and what to look for the issue.
    There is also a panel behind the glove compartment inside the cab and a module of some kind in the passenger side storage compartment.
  5. RSQ20
    RSQ20 Medium Load Member
    With 14vdc at the battery, and 12vdc at the fuse panel.. Check for a high resistance connection between the two....
    If you are able to test the feed wire (Disconnected at fuse panel), the measurement with no load should be no more than .5vdc lower than battery....
    ... Philip
  6. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Add you some extra braided strap ground cables from engine to chassis, and from chassis to cab, you can also go from battery ground to frame chassis rail. Won't hurt nothing, just make sure they're heavy enough to carry the load in case your system is hurting for a heavy voltage ground. In other words you don't want to run a # 16 wire and watch the smoke show.
  7. Mooose
    Mooose Light Load Member
    161
    61
    Apr 13, 2014
    Sherwood Park,AB
    Normal charge rate is 13.9 volts, when your rate starts consistently dropping below 13 volts your going to have problems.
  8. sailboatjim
    292
    173
    Aug 27, 2014
    Boston, Mass
    I don't think you understand. I have 14 volts at the battery and the alternator terminals. No problems there. I have 12 volts on all fuse panels. Gage shows 12 volts.
    Thought someone else may have seen it before. I'll find it eventually.
    Truck works fine right now. No problems with light or anything like that. Yet
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Gauges are sometimes inaccurate. Is 12V what the gauge reads or what your VM reads at the gauge terminals?
    I don't know much about these newfangled computer trucks. Is the gauge traditionally wired or does it come from the ECM?
  10. RSQ20
    Did you complete the test I prescribed?
    .... Philip
  11. BeenJammin
    256
    118
    Dec 17, 2013
    Looking at a 387 schematic, you go from battery positive to a series of mega fuses for each load center. See what you got from battery positive to the mega fuses, and then see what you got from mega fuses to cab fuse load center etc. Are all load center voltages lower or just the cab panel one? Schematic also shows an optional battery disconnect switch, which would supply voltage to mega fuses, too. Another thing about the ground situation, are you reading your volt meter with it directly grounded at the bateries?
