14 Liter Detroit EGR ECM on 12.7 liter Engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Smellfunny, Apr 3, 2017.
  1. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Can you use a 14 liter ECM on a 12.7 engine for test purposes only? Both are DDEC 5 and EGR engines.
  3. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    If they're both DDEC 5 engines it should run off it with no problems. It might not be set up for that truck though so things like throttle and cruise control might not work
    Smellfunny Thanks this.
  4. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    I didn't know if there was any timing differences. I called WW Williams and 2 people I spoke to didn't even know there were 12.7 EGR motors. SMH
  5. benjamin260_6
    430
    480
    Aug 8, 2012
    Ontario, Canada
    Most places you go, they either don't know that there was a 12.7 EGR engine or they don't know there was a 14 pre-EGR engine...or both.
    Smellfunny and Peterbiltt Thank this.
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    it will work ecm might be set up for the wrong truck but motor will run fine
