14 cascadia. 4 codes. Nox, poor def, derate
Discussion in 'Freightliner Forum' started by irishluck09, Mar 24, 2021.
  1. irishluck09
    irishluck09 Light Load Member
    268
    133
    Nov 24, 2019
    14 cascadia with dd13
    Ive been dealing with this issue for about 2 months now.
    Warning light pops on, then check engine and flashing def light.
    Spn 3364 fmi 2
    Spn 5246 fmi 16
    Fmi 5246 fmi 15
    Spn 4364 fmi 18
    A few weeks ago i changed the output NOX. The check light stayed off for the most part but came back. Would stay on for about a minite then go away. Or i could stop and do a regen on it and code would dissapear. Last weekend i changed out the DEF filter figuring maybe this was the issue. Nope. Currently sitting on ramp doing a regen now so i can make it home still.
    So obvouisly my issue is still here and i thought i fixed it. What do i look at next?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Given the age of your truck, the catalyst in the SCR part of the One-Box is probably worn out.
    That’s all the exact codes I got last spring on mine. Eventually the dealer installed new injectors and a new One-Box, fortunately in my case I still had factory Extended Warranty.
    Expect $14,000 bill to replace it.
  4. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    The "Death Codes" 1 box time. Sorry.
  5. irishluck09
    268
    133
    Nov 24, 2019
    I think ill delete it before i put out $14k lol
    BoostedTeg Thanks this.
  6. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Did you findout the issue?
  7. Birdman 008
    Birdman 008 Bobtail Member
    24
    5
    Apr 10, 2021
    Use pittsburgh power max mileage $140 for a half gallon made my code go away use 1oz per 25 gallons of fuel it makes exhaust burn hotter through the dpf, I have lower soot levels even less regens now. The stuff works I promise. And keeps nox levels better. I replaced every sensor and light was still on. Heard about this stuff and I will never stop using it. No more code
    Pittstruck Thanks this.
  8. irishluck09
    268
    133
    Nov 24, 2019
    Yea we just replaced the fuel doser and def doser and still no fix. Truck still derates. But i can manual regen and it fixes it for a day or so. My soot levels are good on dpf as we checked them. Just not sure what else is goin on here.
  9. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Told you what is going on. I deal with this on almost a daily basis. I sympathize with you because of the repair cost, but it does not change the diagnosis.
  10. AlexD13
    298
    85
    Jun 13, 2016
    What Do you guys think of the 400HP engines
  11. Birdman 008
    24
    5
    Apr 10, 2021
    Spend $140 on a half gallon of that MaX Mileage . It will slowly clean the aftertreatment. I'm ordering a gallon this time for $220 should last a long time and it will pay for itself it actually gives a little better fuel MPG. I live by this stuff now. I replaced every sensor and still had the codes. Used that Max mileage and the code cleared on it's own the next day
