13 speed transmission gear shifter/lever too much play/ loose / not tight whats wrong
Discussion in 'Volvo Forum' started by bravoo67, Aug 20, 2014.
  1. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    Hi
    I'm thinking of buying a Volvo with cummins isx and 13 speed transmission.
    Mileage is 150k on it. Checked it on carfax and looks legit
    Just one concern I have is the gear shifter knob, its so "loose", not tight, lever goes all the way to the right and when shifting
    in to 3rd/7th gear I can almost hit dashboard with it
    I know its not normal because on my friends truck ( same engine and trans with 890k miles) shifter lever doesnt have so much play
    My question is.. whats wrong? is it something deep in transmission or something smaller that can be fixed without taking tranny out??
    any input will be greatly appreciated!
  3. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    More than likely in the linkage, no need to go into transmission. However, a mechanic can confirm that is just a few minutes, get it checked before signing on the dotted line.
    bravoo67 Thanks this.
  4. muff
    muff Light Load Member
    73
    38
    Dec 20, 2010
    ontario,Can
    are you sure it`s 150 k and not 1,150,000 miles ?
  5. jbatmick
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    I was thinking that. Not usual for a shifter to get sloppy in 150,000.
  6. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    yeas its 150k
    check it with carfax, ecm shows 150k miles and 7k engine hours on it .. it was a local truck
    and since the transmission is 13 speed not everyone might know how to drive it..
    I consider many drivers with small to non driving experience but 1,150k miles seems more reasonable
  7. jbatmick
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    13 speed in a local truck ? City truck ? Rather odd, but what do I know ?
  8. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    Yes truck has wet line and 530hp isx , double exhausts, no leaks whatsoever.. would say full option
    Is it possible to "adjust" mileage on it ? maybe somebody before inspection/title change - was "adjusting" it ??
  9. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    The Shifter Bushing/ Isolator needs to be replaced, there's no need to take the transmission out.
  10. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    One Volvo (2002 VHD?, higher milage twin of the truck I learned roll.off in on weekends) on the farm was sloppy like that, it was a spare and drivers were forever hitting the differential lock switches shifting to 3rd/7th....this was an 18 speed Eaton-fuller mind you, but it was made good as new with new bushings despite the 87X,XXXkm on it at the time......
  11. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    im gonna hook up cummins insite and read all the possible info to figure out if 130k mileage is possible, kinde fishy since the truck is 2004
    on the other hand have a friend and he has freightliner from 2000 with 350k on it
