13 speed shift knob air lines
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W Bench Farms, Jan 7, 2022.
  1. W Bench Farms
    W Bench Farms Light Load Member
    210
    351
    Oct 16, 2017
    I'm in the process of a 10 speed to 13 speed swap. Have everything ready to go, and hooking up the airlines to the shift knob. I'm running into an issue here. I have everything hooked up correctly to the knob by the book. However, I am getting air back to the shift knob to the H/L line when on the low side. This line should have air to it when on the high side, so that there is air to the splitter. This is on a 16913a, but an early model non-Halo. I'm wondering if there was an early version shift knob that may have the air going to the P port when in high instead of low. I'm at a loss on this one.
  3. W Bench Farms
    210
    351
    Oct 16, 2017
    I'm doing some research, and I'm wondering if this is not a 15 speed instead of a 13 speed. No tag. The salvage yard I purchased from verified it was a 13. So, if this is the case, and it is a 15, I know I'll need a different shift knob. What is this going to do to my ratios?
  4. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    What are you running for gears and tire size ?
  5. W Bench Farms
    210
    351
    Oct 16, 2017
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Eaton Fuller transmission rations: It lists them all but there are many possible that look the same.
  7. bjytech
    bjytech Light Load Member
    229
    207
    Nov 9, 2013
    Have any pictures of the trans and the air setup that is on it? I may be able to tell from them.
    If it is a 15 speed you will know once you start driving it, on a 15 the top gear is over and up towards the dash, where a 13 speed it is over and back away from the dash.
  8. W Bench Farms
    210
    351
    Oct 16, 2017
    Not sure if you can tell from this picture, this is the only one I have at the moment.
    What is making me think it's a 15 is that I have air on the h/l line back to the shift knob when in low, not in high like a 13 should be. I have a new A6913 shift knob on it now.
    It's making me sick thinking I'm going to have to pull it.
  9. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    A 13 SPD OD supply line should feed off the top of that type slave valve not the bottom.
    Dino soar and wore out Thank this.
  10. AModelCat
    154,540
    Not all 15 speeds have top gear against the dash.
    Roger McG and BoxCarKidd Thank this.
  11. bjytech
    229
    207
    Nov 9, 2013
    cant really tell much from that picture, looks like it may be a 15 but would need to see the back side(output shaft side) to be sure, a 15 speed will have a combination range/splitter fork housing where a 13 or 18 would have separate housings for the range and splitter forks.
    I stand corrected, Guess I haven't seen any of the 9 series 15 speeds yet.
    Reason for edit: added pictures
