12 volt scanner printer
Discussion in 'Flatbed Trucking Forum' started by cke, Nov 30, 2016.
  1. cke
    cke Road Train Member
    5,861
    71,831
    Aug 4, 2013
    Colfax Wi
    Anybody got a 12 volt scanner printer in their truck. If so what kind, where did you get it, how much did it cost, can I run it from my I phone or do I need a lap top computer
    snowman_w900 Thanks this.
  3. Ruthless
    Ruthless Road Train Member
    8,791
    86,002
    Aug 28, 2010
    The City.
    Get a wireless air printer and you can from your phone. With a small inverter it works fine.
    I have a HP Envy that I use and have no complaints.
    Probably want to make sure it will have a smooth ride tho, bouncing off a shelf onto the floor won't be good for it.
    CAXPT, rabbiporkchop, Lepton1 and 2 others Thank this.
  4. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Honestly you ate better od to get a cheap inverter and 110v scanner/printer. They don't use much juice so even a small inverter will suffice. And they are readily available rather cheap for a version to work through Bluetooth with a phone.
    CAXPT, cke, Big Don and 1 other person Thank this.
  5. blacklabel
    blacklabel Heavy Load Member
    870
    1,268
    Nov 6, 2011
    MO
    I use an Epson xp420 it's cheap. USB cord and a mico USB adapter and an app print away... it's 110
    CAXPT, cke and snowman_w900 Thank this.
  6. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Yeah, I second... err, third... fourth? Anyhow, don't bother with a 12v or "portable" printer. They're expensive and don't perform as well as regular ones (I've used both). As recommended, just get a small inverter (one that plugs into a 12v socket) and then get the printer of your choice... there are plenty of choices with WiFi and Bluetooth.
    CAXPT, GYPSY65, cke and 1 other person Thank this.
  7. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    I use an HP office jet 250. Its a compact and wireless printer. I can use my laptop or iphone with it. I have had great luck with it.
    If you do buy a good printer and inverter, try to get a pure sine wave inverter. Electronics like printers and game consoles, some dvd players and other sensitive electronics work better with pure sine wave v.s. modified sine wave.
    Modified are cheaper, but sometimes dont runs certain electronics.
  8. old iron
    old iron Road Train Member
    1,126
    19,701
    Feb 19, 2011
    Northern Wi
    I'm on year 4 with the cheapest Walmart household printer I could find. I'm not smart enough to get the wireless to work with my phone/laptop. That would save an entire glove box full of tangled and knotted up cords.
    Mine rides around under the bunk in a 48" flat top so things are always piled on top and so far it still works. Every so often it needs the junk blown out of it with the boot hose.
    CAXPT, Lepton1 and cke Thank this.
  9. old iron
    1,126
    19,701
    Feb 19, 2011
    Northern Wi
    Almost forgot. Whatever you do get, make sure to get a ton of extra ink cartridges. Nothing is worse than hunting for ink in the middle of Montana all the while trying to close the deal for the only hot $$$ load in 500 miles.
    CAXPT, Lepton1, cke and 3 others Thank this.
  10. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    right now I have an Epson 420 I think, it takes up a lot of room in a daycab and the ink doesn't last long I don't know if its the temperature swings or what it also has connectivity issues sometimes. Here's the one I'm getting, i think it'll be better at least I hope.
    https://www.brother-usa.com/mobile/lp/pocketjet7/
  11. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
    I had looked at that before and I believe it would be a good setup. I asked to look at a troopers once and I believe that's what he was using. Ink runs out at worst possible places and odd times
    cke Thanks this.
