This started out with the fan not kicking on at 210*, coolant temp got up to 225 on me, and for the rest of the trip I drove it gently to keep ECT down. I figured if it ended up being an issue I could pull over and unplug the solenoid on the front cover and force the fan on all the time. There was only one more hill on my route, and I was careful to keep the temps down but they did get up to 220* on me. At the end of the day I find that coolant had been forced into the overflow and I was empty on the side you fill. I topped it off and headed home, now it is puking it out too fast to risk it so I'm finding a shop or having it towed. It got up to 230* on me so I let off and coasted into a truck stop and not risking doing anymore damage.
Anyone have any ideas? 98 Volvo just hit 1mil yesterday.
12.7 Detroit pushing coolant out of overflow
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Terry270, Aug 7, 2018.
Page 1 of 7
How old is the reservoir & cap? I have a 1998 D12 and replaced the reservoir + did coolant drain & fill.
I have not had a problem with rising coolant since.
All that done 35K miles ago, in March 2018.
RubyEagle, Oldironfan, VWbeagle and 1 other person Thank this. -
Oldironfan Thanks this.
Coolant temp goes up, as you go uphill. The fan clutch is supposed to trigger at 210* (or some number near that).
Is your fan clutch working? -
Test the fan.
While engine stopped. Try turning the fan with a stick, see if its grabbingOldironfan Thanks this. -
The test above, assumes motor was cold.
Anyways, check this video.
Terry270 Thanks this. -
Page 1 of 7
