Greetings. I have a 2007 Volvo day cab with D12 465hp engine, 10 speed trans, and 3.58 rears. Truck has 11R22.5 tires. It's near time for new tires. Should I switch to lowpro 22.5, which my two trailers run? Or should I stick with the 11R's? What will I gain or lose by switching to the lowpro's? Truck currently averages 6.5 mpg. Thanks.
11R22.5 to 295/75r22.5 What will I lose or gain
Discussion in 'Ask An Owner Operator' started by silver dollar, Jun 21, 2021.
Your rpms will go up by about 100-150 at cruising speed
silver dollar Thanks this. -
I hate Low Pro Tires. I may be in the minority but I hate them.
They say you have less rolling resistance so maybe you will get a little better mileage I don't know. But they are closer to the rim and that's got to make your truck ride more rough. And I think they look ugly to boot.
If Al Bundy had anything to say about it, he would call them mamby pamby girly man tires. And he needs a man-sized flush like his father... I guess that's for another thread, lol.
Ugly:
Nice:
Ssgtkevin, Stray_Dog, Speed_Drums and 4 others Thank this. -
At the same psi, youll mostly loose a little load rating, rpms to maintain same speed will be 100-150 rpm higher, (that may be good, may be bad for your setup, not sure, i went the other way and had to drop a gear to maintain my rpm at where i was because that was already the sweet spot, you dont have another gear to hit going higher so if you run too low a rpm, thats a good move, if already correct or too high, prepare to drive slower.
Mpg will increase marginally on better rolling resistance (.5% better) (but see previous paragraph, driving style and rpm make more of a difference) ride will be 5% stiffer (mpg will *look* worse unless you correct your odometer to what the truck now has)Ssgtkevin and silver dollar Thank this. -
Might be just as easy to eventually switch the trailer tires out.
Ok
I respect your opinion... -
I think 24.5LP looks good tho on a large carFinal Drive, Roger McG and baha Thank this. -
Might want to ck availability of 22.5 standard....22.5 lo easily found standard 22’s aren’t typically carried by many anymore
Diesel Dave and silver dollar Thank this. -
Thanks everyone. I'm gonna stay with the 11R's on the tractor and switch the trailers to 11R's when they need tires. Thanks again.
