11r 24.5
Discussion in 'Trucks [ Eighteen Wheelers ]' started by seinb, Jan 28, 2012.
  1. seinb
    seinb Light Load Member
    102
    9
    Dec 19, 2011
    richfield id
    i have 285 75 24.5 steers. whats the difference in a 11r 24.5 found good deal on 8 Virgin tires
  3. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    The 285/75 24.5 tires are the low pro design which mean shorter sidewalls compared to the standard 11R24.5. You can install the standard tires, but your front end will just sit a tad higher if you are putting them on the steer. If the 8 tires are gonna go on the drives then you will need to recalibrate your speedo due to the extra tire circumfrance if you swap from the low pro to the standard or vise-versa
  4. seinb
    102
    9
    Dec 19, 2011
    richfield id
    That's what I needed thanks
  5. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    You might want to check and see that they don't put you over height!
    They will be 2 inches taller than your low profile tires .
    Other than that you should be ok .
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    YES! Check the height change of the 5th wheel putting on those taller tires, many drivers have made convertibles out of trailers by making this change and NOT checking the height change!
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    They may be 2" taller, but that's the diameter difference of the tire. It will only increase the ride height by 1".
    Also, be careful if your truck has fenders or any other equipment mounted in close proximity to the tires. If mounting on the steers, make sure the tires can turn all of the way from one side to the other without ever rubbing on anything.
  8. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    Fifth wheel 48" max height to vans
  9. Diesel Dave
    8,520
    23,430
    Jan 20, 2010
    Hesperia, Ca.
    If you don't mind me asking, what brand are they and what was the the price on the deal ?
  10. seinb
    102
    9
    Dec 19, 2011
    richfield id
    Contenal 50 each
  11. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    50.00 each? Is there a truck sitting on the other side of the shop on blocks? That sounds like go to jail prices.
    anyhow...
    Make sure they are all the same size. We have had guys buy tires like that and get a mix of 4 lo-pro and 4 tall rubber and it will destroy your rear end and you end up with bad tires as well.
