10w30 oil for my 2015 cascadia
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, May 27, 2020.
  1. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    Where are you guys getting your oil from? Ide like to start doing my own PM’s and just wondering where you guys are getting the oil from in bulk. I believe our DD13’s take 47 quartz??? Thank you
    Rideandrepair Thanks this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
  4. Oakland Raiders Forever
    Oakland Raiders Forever Medium Load Member
    393
    451
    Feb 24, 2020
    When I owned my own equipment I liked using Sheaffers oil. Better oil samples and I don’t think I can prove it (in a for sure scientific way) but I picked up a little fuel mileage replacing engine , trans , diffs with there brand oils fully synthetic oils that is. Google it I think they only sell through independent dealers.
  5. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
  6. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    Delvac @ Wally World. Always on a roll back, $10.50 or so, a gallon. Filters from Freightliner Dealer, .preferably Detroit Fiters, sometimes cheaper than Fleetguard. And Lucas grease. It’s worth a couple xtra bucks.
    PE_T Thanks this.
  7. Transportacion R&R
    175
    73
    Apr 10, 2020
    I will most likely go with Delvac as well, thats what im looking towards. Which Delvac did you use? 10W30? etc... Full synthetic?
    for example - Mobil Delvac™ 1300 Super 15W-40
    MOBIL DELVAC 1300 CK-4 15W-40, 5 Gallon Pail
  8. Transportacion R&R
    175
    73
    Apr 10, 2020
    Also are you putting in 47 quarts or 41 quarts? 4 quarts to a gallon, meaning 47 quarts = 11.75 gallons? 11 galons and 3 quarts
  9. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    15w40, pretty much Industry standard. They also have Rotella, and Delo. It’s the same oil, just different additives.I usually go 20k, , but since I had some sludge issues, and recently had an OH, I’m going back to 15k, Might be better choices for you, especially with extended intervals, and synthetic options. I had been using a lot of Lucas, up to 3-4 gallons between changes. Before that though, I never had a sludge issue. However I’ve heard, and do believe that Rotella will keep an engine cleaner, they claim Delvac has silicone type additives, that put a film on everything. I don’t know. Old way was Rotella for Cats, and Delvac for Detroit’s. So I stick with that. Hasn’t failed Me yet.Always a head gasket or dropped liner. Never oil related.
  10. Transportacion R&R
    175
    73
    Apr 10, 2020
    I appreciate your help, I use Mobile 1 on all my cars. What truck do you have, mine is 2015 cascadia DD13 and i plan on every 20k miles. Seems like I will stick to the Delvac full synthetic 15w40. Ive hearfs 47 quartz, ive heard 41 quartz. DD15 uses 47 i believe.
  11. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    I’m pretty sure my 12.7 takes 10 gallons, sometimes a little more, if I get a good drain. I always pre fill filters, very important.
