10k axles how to torque lug nuts to 200 ft lbs
Discussion in 'Ask An Owner Operator' started by Rockwind1, Sep 22, 2022.
  1. Rockwind1
    Rockwind1 Bobtail Member
    27
    9
    Sep 22, 2022
    I had to work on the brakes on my gooseneck has the older Dexter axles 10,000 pounds but it’s kind of a new trailer to me so not an expert on it yet and I looked up the torque for my 5/8 cone shaped like nuts on a steel rim for Duel-lies but says 190-210 ft lbs. tha t a lot But I don’t have a torque wrench that goes that high. I just used a cheater bar on my three-quarter inch drive ratchet handle and I got them pretty tight but I have to be put in close to 200 pounds on them
  3. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Head to a tire shop many will retorque for a small fee or free if you’re a customer..
  4. Ridgeline
    22,101
    113,191
    130 to 170 ft/lbs for a 10k axle, check and retorque at 25 and 50 miles.
  5. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    You can get an inexpensive torque wrench at Harbor Freight.
    Don't mess around with taking a guess on how tight or loose your lugs are. Get yourself a $50 torque wrench and don't worry about your wheels falling off.
  6. W923
    W923 Road Train Member
    1,292
    3,923
    Feb 28, 2022
    With a 1 inch drive impact?
    I haven’t seen a tire shop use a torque wrench in forever
  7. 77fib77
    77fib77 Road Train Member
    10,167
    62,752
    Jul 7, 2010
    St Louis
    The TA does. They use it to tighten after the suggested 50 miles.
  8. Magoo1968
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Only jerks do final torque with impact gun .. here in Canada many provinces will go after shop in a wheel off situation if shop just installed wheels and it’s under 60 miles after that it’s up to driver to retorque wheels.
    MartinFromBC and Bean Jr. Thank this.
  9. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    I got this on Amazon. This one is a 3/4 drive that will do up to 750 ft-lb if memory serves. They make all sizes. This one was about $100. You set the target torque first. Then as you start getting close, it starts chirping then goes to a solid tone when you hit the setting. Handy if you're stupid like me and set up the tool facing the wrong way, or you're working in the dark.
  10. Ridgeline
    22,101
    113,191
    wow, the axle manufacturer says in their little maintaince manual - 130 to 170 ft/lbs for a 10k axle, check and retorque at 25 and 50 miles.
    Not 200 ft/lbs.
    That said, I seem to think it is better to torque them down a lot more than 170.
    Bean Jr. and RedForeman Thank this.
  11. RedForeman
    4,875
    22,138
    Jan 30, 2011
    That got me wondering, since it's been a minute since I dealt with stud centered hubs. E-trailer has a chart posted showing both. The lower value OP mentions is for aluminum wheels, the higher spec you mention is noted for steel wheels.
    Rockwind1 Thanks this.
