10 Meter Radio "Conversion" Question
Discussion in 'CB Radio Forum' started by The Gryphon, Nov 3, 2015.
  1. The Gryphon
    The Gryphon Heavy Load Member
    826
    445
    Nov 3, 2011
    When someone "converts" a 10 meter radio for use in the 11 meter band do they lose access to the 10 meter band, or does the "conversion" ADD the CB channels to what is already there?
    darthanubis Thanks this.
  3. handlebar
    handlebar Heavy Load Member
    The ones I've had on my bench both add 11 Meters *and* change the 10 Meter band segments the radio covers. My own rig is an Emperor, and once enabled the band switch toggles through 4 or 5 channel banks. I can't speak to the other more commonly seen import rigs.
    Several of the import rigs, right out of the box, only cover 28.000 to 28.295, but those freqs are all within the non-voice (Morse, digital modes). Which is kinda pointless for a radio that can't do anything other than AM voice.
    The CB Tricks site can probably give you more specifics based upon the actual make & model you're thinking of getting.
    Hope that helps some.
    73
    rabbiporkchop and The Gryphon Thank this.
  4. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
  5. darthanubis
    darthanubis Heavy Load Member
    825
    616
    Jun 26, 2015
  6. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    On my Galaxy 99v2 band E is 11 meter, band F,G,H are 10 meter and bands A,B,C,D are all below 26965.
  7. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Correction: Band F is 27415 to 27855, Band G is 27865 to 28305 and Band H is 28315 to 28755.
  8. darthanubis
    825
    616
    Jun 26, 2015
    I'm not sure what your are saying in relation to the question? Did you lose any frequencies or bands after conversion?
  9. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Well I guess 10 meter is 27000 to 29700 so I guess they are all not there, dont know if they were all there before conversion to 11 meter.
  10. wolverine11
    1,629
    1,234
    Apr 1, 2015
    10 meter starts at 28000 not 27000, Im confused will stop posting
  11. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Converting the Icom7000 you don't lose any channels....
    Evvy Thomas Thanks this.
