+10 kHz
Discussion in 'CB Radio Forum' started by BTShepp, Jan 24, 2017.
  1. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    The "+10kHz" switch is a funny thing. It only gives the operator 5 extra channels within the CB band. Today, just for kicks, I was monitoring and transmitting on channel 18 with the switch on. Some might call that channel 19. I also learned that channel 23 is a frequency between channels 25 and 26. I'm late to the party of frequency assignments.
    Are those 5 extra channels legal? They're not assigned CB channels, but they exist within the legal CB band. I'm not asking because I use them or that I'm worried about the consequces from the FCC-- we all know that's a joke. It's a peculiar situation. Unlike freebanding, these "split" channels aren't out of the band. It's a matter of semantics, I suppose.
  3. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Pretty sure it's strictly illegal
  4. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
  5. Ridgeline
    22,116
    113,354
    Those 'in between' channels were set aside for things like garage door openers, RC planes and so on. Some of it was a compromise for the band being taken from the hams, a bunch were using it. If the band plan was setup right, those channels would not be provided.
    BTShepp Thanks this.
  6. CW Spook
    CW Spook Light Load Member
    Back in the good 'ole days of 23-channel radios, it was pretty common to find 22A in radios like the original Courier 23. I don't know why the other 'extra' channels weren't included, but I suspect it has something to do with the way the frequency synthesis system worked and/or it being more cost effective to use a 24-position channel switch. Those channels have never been legal for CB use, but 22A was quite popular with skip-shooters as it was more likely to be clear, back when many folks were still using 5-10 channel crystal controlled radios.
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    The 10 khz switch gives access to the following frequencies:
    26.995 (between 3 and 4)
    27.045 (between 7 and 8)
    27.095 (between 11 and 12)
    27.145 (between 15 and 16)
    27.195 (between 19 and 20)
    Note...any "certified" 11 meter CB does not have these capabilities in stock form. The above frequencies were set aside for RC toy operations.
    Which can be kind of fun if little Jimmy is flying his 27 MC RC airplane and you happen to have a splatter box radio, you key up and cause his plane to do uncommading movements.
    Then again it's a bit absurd and childish to do to anyone unless you know them and are just messing with them in good humour and they understand it as so.
  8. Beighley02
    Beighley02 Bobtail Member
    18
    4
    Jun 20, 2018
    Hey Rabbi see you promoting marks work allot what is the estimated wait to get a response from him if you pm him
  9. Ridgeline
    22,116
    113,354
    The CB tech god ... takes his time in responding and if you get out of line, then you get "no soup for you".
  10. Beighley02
    18
    4
    Jun 20, 2018
    Yeah that's y people don't let me him
  11. Triple Digit Bullhauler
    Triple Digit Bullhauler Heavy Load Member
    927
    1,263
    Sep 6, 2012
    001 anywhere USA
    The 10 khz switch by my understanding splits the channel. Anyone on a channel, without the 10 khz will only hear distorted transmission.
