'10 International 4300 with 196k miles concerns...
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MattyNJ1, Dec 12, 2018.
  1. MattyNJ1
    MattyNJ1 Bobtail Member
    Considering upgrading to a '10 International 11' mason dump great running truck new dump body but im concerned about the 196k miles on the MX DT 466, 225 HP , 6 Cyl...trans is Allison, Auto, 2100 HS.
    Any advise? truck is 29000 gvw. Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    This is about the time it needs turbo de-coking, EGR cooler, DPF and DOC. Check the exhaust manifold for any sooting because they are prone to cracking too.
    MattyNJ1 Thanks this.
  4. MattyNJ1
    Yikes.........what is the life span of the motor....generally? Is 200k miles something to walk away from?
  5. Heavyd
    7,749
    6,184
    Feb 4, 2009
    The core motor isn't bad. It's all the emissions stuff bolted around it that doesn't last. Google search for Maxxforce, all your questions will be answered.
  6. jake744
    jake744 Light Load Member
    126
    138
    Dec 27, 2017
    Another problem with that engine is they turn lifters and eat the camshaft up. Navistar used a flimsy piece of sheet metal,well little thicker than that but not much to hold the lifters and it breaks thus turning lifters sideways. Don't know how common it is but I have 3 sitting at shop we use for cores all with bad cam and lifters. Mileage on them vary from 100,000 to 300,000.
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    The cam follower retainers are certainly an issue that are most predominant with 07 Maxxforce emission models. Those have a bit heavier valve spring with only a single cam follower retainer compared to the previous EGR only 2004 emissions model. 2010 Maxxforce emission model engines were built with doubled retainers to eliminate the issue.
    soultrader and MattyNJ1 Thank this.
  8. jake744
    126
    138
    Dec 27, 2017
    Thanks I didn't know they updated the later models. I had heard it was an upgrade to double up the retainers when replacing cam and lifters.
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yes, two will fit no problems on older ones.
