10 hr break?
Discussion in 'Questions From New Drivers' started by Sixela918, Mar 18, 2022.
  1. Sixela918
    Sixela918 Light Load Member
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    I'm sure this is something I should know already, but this hasn't come up for me yet. I arrived at my delivery at 0200 this morning (I went off duty), but they weren't ready for me to swap out the trailers until 0700. At which time I went "on duty - yard moves" and swapped trailers, then went back off duty (at 0730). In this case will my 11/14 reset at 1200 (10hrs from when I last was in Drive)? or at 1730 (10hrs from going back to off duty from using yard moves)?
  3. TripleSix
    127,950
    From the yard move, not the drive. You had 5 hours in too. That really sux. If it were all possible, I would have PC’ed that one.
    Bean Jr., tscottme, Chieftains and 3 others Thank this.
  4. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    Crap, that's what I was afraid of. I thought about just keeping it below 5mph while swapping trailers (therfore not triggering the automatic switch to drive), but was worried that I might go just a little too fast. Well, now I know. Lesson learned. Thanks for the reply. Looks like I gotta try to sleep during the day. I hate that.
    Bean Jr., TripleSix and D.Tibbitt Thank this.
  5. keebler13579
    keebler13579 Heavy Load Member
    910
    1,756
    Nov 16, 2012
    Take a 7in the sleeper. Can leave at 1530 with 11 d and 1330 left in your 14. If you went off duty instead of sleeper then you will need a full 10. This is why you always put it in sleeper not off duty
    Bean Jr. Thanks this.
  6. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    Yeah, you should set the SB Spilt on your ELD. It will give you back that 5 hours on your 14 and then when you do finish and get stopped, don't forget to take the 7 hr in SB part of the split. Even if you take a full 10 after this, still need to show the 7 hours, continuous, in SB. Good news is you can take the 10 hour and 7 hr sleeper berth concurrently. Don't need to take 9ne and then the other. But, you gotta show 7 continuous hours in SB or it's as HOS violation.
  7. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    So it has to be sb, not off duty?
  8. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    Yeah, the split sleeper option is something that I can't seem to wrap my head around, and I'm afraid to hit that button. Would it help me in this situation? IMG_20220318_130245__02.jpg
    I need to drop this trailer about 7hrs away
  9. keebler13579
    910
    1,756
    Nov 16, 2012
    Nope finish your 10 and go youll be fine
  10. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    Ok. That's pretty much what I figured by now. Thanks
  11. keebler13579
    910
    1,756
    Nov 16, 2012
    From now on go in SB not off duty so you can use the split
    tscottme Thanks this.
