1 Pushrod on slack adjusters longer than the rest
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HP510, May 24, 2023.
  1. HP510
    HP510 Bobtail Member
    25
    8
    Sep 4, 2019
    One pushrod on my slack adjusters are longer than the other 3 on axle 2 and 3. All the brakes are adjusted. Brand new truck 90k miles. When parking brakes are applied it all looks the same, does the pushrod that’s sticking out need to be cut to length?
  3. AModelCat
    154,281
    If they are all correctly adjusted and look the same with the brakes applied I'd lean towards the one with the longer pushrod not fully releasing.
    HP510 and Rideandrepair Thank this.
  4. HP510
    25
    8
    Sep 4, 2019
    My bad I meant when parking brakes are released it all looks the same but when it’s applied one is longer than the rest.
    Rideandrepair Thanks this.
  5. AModelCat
    154,281
    Sounds like the longer one isn't properly adjusted.
    Measure the stroke on each chamber.
  6. HP510
    25
    8
    Sep 4, 2019
    Ok I will check tomorrow and let you know how it goes
  7. HP510
    25
    8
    Sep 4, 2019
    You’re right I had to adjust it
    Rideandrepair and Bigtruckdrivah Thank this.
  8. HP510
    25
    8
    Sep 4, 2019
    How often should slack adjusters need adjusting? One went out of place a day after I adjusted it but the other 3 seems to be okay. Is that normal? I greased all my slack adjusters
  9. AModelCat
    154,281
    Auto slack adjusters should never require adjustment if they are set up correctly and maintained. Besides whenever they've been backed off to do brake repairs of course.
    If its not keeping adjustment it is more than likely time to replace it.
  10. AModelCat
    154,281
    Should still regularly check that they are staying in adjustment though.
