1 or 2 Predator 10k antennas on a 2022 Cascadia
Discussion in 'CB Radio Forum' started by Toddalmighty65, Oct 26, 2021.
  1. Toddalmighty65
    Toddalmighty65 Bobtail Member
    I have a 2022 Cascadia, and am running a Galaxy hp40w. I am using a 4' firestick ll, but getting poor reception. I have been reading on the forums and have decided on the Predator 10k 27. My question is it worth running a pair? I am going to bond the doors to the body.
  3. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    0 10k's.....Wrong antenna for what you want...
    Great antenna for the classic style truck but not on a low mounted mirror areo truck..Such a long shaft and wind drag of the coil makes it hard on the bracket and stud,keep in mind the sticky finger crew will have easy access..No point in spending $200 on a cpl ant then more on stronger studs n brackets when a longer version(6 or 7ft long skip shooter or firestick)will really get you where ya wanna be,besides your radio assumeing its at most been peaked n tune doesnt put out the big power a 10k is designed..I have packed away my 10ks..
    Bonding will be a big issue,workin on that myself..
    Look me up on youtube i did a basic vid on this very subject today..
    K0bg.com on some info about bonding..
    Bbi on youtube has done some hands on stuff about the straps and shows how he bonded his suv which will help
    Lotsa threads here to re an antenna set up on a plascadia..
  4. Toddalmighty65
  5. Toddalmighty65
    Thanks for the info, i had been considering a 7ft Skipshooter. But i have seen a few reviews stating the Skipshooter broke from road speed. If i go with the Skipshooter my question still remains, is 2 better than 1? Also i will definitely check out those YouTube videos.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If it were me....I would go with just one single coil 10K...:thumbup:
  7. Timin770
    Timin770 Road Train Member
    1,657
    1,757
    May 27, 2011
    Canton, GA
    I'd do one single Skipshooter, as long as you dare
  8. craig_sez
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Go with 1 skip shooter and use a 2-3 ft piece of 3/4" pvc water pipe..Not the black heavy stuff though or copper..
    Toddalmighty65 Thanks this.
  9. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    I see no reason to spend that kind of money for that antenna on that truck when the 74 mile freightliner Cascadia was using a cheap $26 dollar stainless steel whip.
    craig_sez Thanks this.
  10. craig_sez
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    If i could find another $26 whip i would have one....Shipping from the usa just makes it nkt worth ordering for me..Asked a few fb trucker friends to grab me one or two,that was months ago...Still nothin....
  11. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    $23.17
    102" Steel Whip - Walmart.com
