09 Cummins ISX 435 ST Low Oil Pressure
Discussion in 'International Forum' started by redcentury07, Aug 2, 2014.
  1. redcentury07
    redcentury07 Light Load Member
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Hi, I am going through so much hell with this problem. My truck has low oil pressure. 20 psi, has been like this since i purchased it at 598k miles. now it currently has 610k miles and at times the truck will shut down when going up on hills at high RPM. I took it to the dealer, they didnt know much. A few mechanics told me it is the oil pump so i went ahead and changed that as well as the main Bearings as well as the oil pressure sensor.. It doesn't turn off as much as it used to since i recently changed the oil and oil filter. Anybody know what is going on??
  3. bad-luck
    bad-luck Road Train Member
    3,252
    5,955
    Nov 16, 2013
    Baltimore, Maryland
    sounds like it could be the oil pressure regulator.you need to drop the pan to replace this. Ashley it's usually recommended that you replace it when you replace the oil pump
  4. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    ISX engines are known to be dirty engines with high soot build up in the oil that plug oil filters. Did you see your pressure come up with the fresh oil and filter?
    redcentury07 Thanks this.
  5. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    I actually did a little. It was going to about 30. Ran Fine for about 5,000 miles and then it started again. I don't have this issue when i am on low RPM while going uphill, only when I am on high RPM. I am just worried it will do damage if i continue running like this.
  6. Feedlebum
    Feedlebum Light Load Member
    59
    39
    May 5, 2014
    I know this sounds funny but are you using any amount of radiator coolent
  7. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Leaking EGR valves can cause the engine to soot up the oil. The low oil pressure is usually temporarily corrected by a filter change. Usually leaking EGR valves throw EGR temp too high, Turbo inlet temp too high and can cause excessive regens. Usually the first thing to do is make sure your EGR differential pressure sensing tubes are clean, and that the venturi pipe is also clear so the EGR differential pressure sensor is reading correctly. This is normally a good time to also clean or replace the intake manifold pressure sensor for being plugged. To check for a leaking EGR valve you need someone with Insite and perform a forced regen. You need to watch the EGR differential pressure during the regen. It should be less then 0.3 inches of Hg. The EGR valve is commanded closed by the ECM during a regen, but if the sensor is reading more than 0.3 that means it is leaking exhaust gases back into the intake.
    CMCtech and redcentury07 Thank this.
  8. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    Also might help a little to be sure and use the longer oil filter. They make a short one and a long one and sometimes the oil change place will just use the short one if ya don't tell em.
    redcentury07 and Heavyd Thank this.
  9. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    I read on another thread that the timing might be off, causing the oil filter to plug up sooner.
  10. Heavyd
    7,750
    6,184
    Feb 4, 2009
    Yes, this is another possibly, low power and poor fuel economy are usually the primary complaints with that.
  11. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    I am burning some oil as well. I don't know if this is related to the issue.
