'07 Columbia no in cab lights/bunk power help!
Discussion in 'Freightliner Forum' started by Topcrop94, Oct 7, 2017.
  1. Topcrop94
    Topcrop94 Bobtail Member
    Oct 7, 2017
    Harvest time is frustrating enough without truck problems. Keeping it simple, My 07 Freightliner Columbia has all 12v outlets, dome light, bunk fan, and interior lights/sleeper in non working state of condition. Just about every piece of literature that I could find regarding fuses/diagrams panel relays has resulted in me posting this thread. Basically, ive Exhausted all the possibilities...at least to my understanding.
    If anyone could shed some light for me, please consider in your reply the fact that I'm here to learn.
    I keep a well maintained truck so frustratingly- theres no obvious causes. All fuses in the dash and behind driver seat are ok. Battery box clean and in line fuses are good. All other details i have are worthless and i need some mother trucking wisdom!! Thankyou!!!!
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Down beside the seat, under the plastic cover that houses the diagnostic connector, you'll find a connector with four small wires and a large 10 gauge wire. I'm betting the connector is melted around the 10 gauge wire that supplies the sleeper with power. Chop that wire out of the connector, crimp a butt splice on it, solder and shrink tube... You won't have any more trouble.
  4. Topcrop94
    Oct 7, 2017
    I got excited because I noticed how dirt and water collects there. Prime spot for a problem. It was a little coroded but it hasmt melted and it tested okay. Still worth a shot
    lilillill Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    check behind the middle console on the floor under cupholders behind the middle storage case should be what looks like a small amplifier this is low voltage disconnect should have two 7/16 nuts connecting bigger gauge cables take a pair of pliers and jump those two together everything should come back if it does either replace it or if not possible to get part you can connect the two cables together with a bolt and should be back in business.
  6. perez05pr
    perez05pr Bobtail Member
    49
    7
    Oct 20, 2010
    ohio
    i have a similar problem but everything in the bunk works except for the ac blower! i already checked everything related and no luck!
  7. Rocket Racer
    Rocket Racer Bobtail Member
    18
    Oct 3, 2011
    IL
    THANK YOU..!!!
    I’ve been dealing with this problem for a couple weeks, now.
    While digging into the dash I saw this flashing lite. -Why is there a “warning lite” INSIDE the dash???-
    After reading this post and investigating further...—BAM!— This fixed my problem. Thanks again @nasriza !
  8. dakappa
    dakappa Bobtail Member
    4
    the lower voltage cut off ,
    50 amp mega fuse below blower motor zip tied to a bunch of wires
    rain shorted out fuse box behind front seat one of these or combo of them
  9. dakappa
    4
  10. dakappa
    4
