07 Century AC fuse keeps blowing, where should I look?
Discussion in 'Ask An Owner Operator' started by Spyro2112, Apr 28, 2019.
  1. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
    07 century fuse keeps blowing, any suggestions wires look good from dryer
  3. Lowboy456
    Lowboy456 Light Load Member
    278
    127
    Mar 14, 2017
    When fuses blow repeatedly its usually a skinned wire touching metal.
    Does the fan continue to run and blow warm air or does the fuse kick everything off??
  4. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Is you fan fuse burning out??
    You will need to clean the air filter for your bunk fan or cab fan.
  5. Lowboy456
    278
    127
    Mar 14, 2017
    Trace the AC compressor wire all the way to the fire wall and look for a skinned place. We had one go bad once inside the bundle going through the fire wall and had to run a new wire from the ac relay the compressor.
  6. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    It would be nice to know what fuse is blowing?
  7. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    I was going to reply this too since he is correct. I am a certified mobile electrician and random blowouts are usually caused by a wire making contact with metal or maybe even its own ground. You could try moving wires around in case they are contacting one another or rewiring the a/c as best you can in the hopes you can fix it. You may also want to check if maybe something else is wired to that same fuse causing the amperage to spike. You could also probably get away with adding a higher fuse as long as it's not too high so that if there is a problem it won't keep the circuit closed.
  8. Spyro2112
    602
    412
    Mar 17, 2018
    Thank to all, trying, on the front of dryer I get 14 v on side nothing on other
    Back of dryer nothing and test light will come on but says no voltage, plug back of dryer no compressor clutch, unplug back of dryer compressor clutch on, mmmm
  9. Spyro2112
    602
    412
    Mar 17, 2018
    When the wires go through the fire wall, r they one piece or is it connected from one side and the the other
  10. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Last winter my fan fuse kept blowing every time I needed defrost.
    Compressor was froze up. Pulled plug off compressor and had defrost till summer came and compressor was replaced.
  11. Spyro2112
    602
    412
    Mar 17, 2018
    Not fan fuse HVAC 20 amp fuse thanks
