06 t600 heater shut off value
Discussion in 'Kenworth Forum' started by Stacie, May 26, 2014.
  1. Stacie
    Stacie Bobtail Member
    30
    4
    Mar 10, 2014
    Md
    I have a 06 t600 i jst bought it last week in pa frm the previous owner the truck runs great i couldnt b happer sofar the only thing i cant get to work is the heat. Y would u turn the heat off if it was still cold in pa where i bought it whn he stopped driving the truck?? Is it safe to think the heater core is bad?? I have my dog in the truck im half afraid to try to open the flow with him in truck. What are your thoughts on this and do u kno what value turns on the flow? Thanks every1
  3. blackcrowntrans
    blackcrowntrans Light Load Member
    133
    73
    May 19, 2014
    He night of had a bad hose and shut it off. To find the valves follow the the hoses that come out of the cab and under the sleeper.hope this helps
    Stacie Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    look for 2 valves on the passenger side of the engine. with hoses that run to the cab like mentioned above.
    1 valve is for the sleeper and the other valve is for the cab heater.
    feel the temperature of the hoses. if they are hot. the valves are open. cold means closed valves.
    Stacie Thanks this.
  5. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    there isn't any shut off valves. only a black plastic electrical valve under the heater box where the lines go into the cab. its either that, or the temp. control knob in the cab .
    Stacie Thanks this.
  6. Stacie
    30
    4
    Mar 10, 2014
    Md
    Ok yea i looked for those two values up by the engine lastnite they werent there ill look up on firewall thanks guys
  7. snowwy
    20,527
    13,262
    Jul 6, 2009
    you've got 4 hoses. 2 of them don't have valves?????
    you can tell if it's a bad core. 2 hoses. if both are hot. the core is plugged.
    the core acts like a radiator. water going in will be much hotter then water going out. there should be a huge different in temperature between the 2 hoses.
  8. Robert Ishee
    Robert Ishee Bobtail Member
