Looking for a bit of help. I have an 05 Cummins ism when pulling a hill at 70 mph you drop down to 55 or less mph loaded or empty. Also truck shakes in when on the gas particularly in high gears. Also shakes like it's missing or something when idling. Anyone with any ideas on where to start would be be greatly appreciated!!
05 Cummins ISM Problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Antravious, Jan 1, 2016.
Get cummins Insite hooked up to it and do an injector cut out test. Sounds like a dead injector for sure.
Funny it would be doing that without throwing a code.
Not at all funny, it will only throw a code if the solenoid on the injector or the wiring to the injector has a problem. If the mechanical part of the injector fails it will not produce a code at all, I have replaced tons on n14 and m11 engines that never produced a code.
my 05 was doing the same thing, it was number 6 also. oh cody you that man.
