03 Century cigarette lighter fuse
Discussion in 'Freightliner Forum' started by Image, May 9, 2012.
  1. Image
    Image Light Load Member
    69
    17
    Mar 15, 2012
    ND
    I was messing with a couple wires in the bunk that had a 12v outlet, trying to splice in a small inverter. And the wires touched and i thought i blew the fuse. Checked the fuse panel on the dash and the "cigar" fuse is still good. But there is no power to the fuse. Its just a 10amp, i would think it should of blew first, but something else must of. I also lost power to the dash 12v outlet at the same time.
    Any ideas?
  3. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    Check in the battery box and by the driver's side fire wall under the hood.
  4. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,054
    Jul 15, 2007
    TEXAS
    I could be wrong but I think the fuse to the bunk outlet, is in the panel behind the drivers seat. That was on a 05/06 Feightliner. Not sure why it would blow the front outlet at the same time, except maybe the 03 was wired different.
  5. truckersrstupid
    truckersrstupid Bobtail Member
    16
    Jun 28, 2012
    Check the B-Pillar PDM. The PDM (fuse panel) is located in the compartment just behind the driver's door. There are a few fuses in there for 12v receptacles....I'm sure there is one blown.
  6. tootie
    tootie Bobtail Member
    Would this be the same for a 1999 volvo?
