I was wondering what the two sensors are on the expansion valve below the passenger seat area and what sensor is in the line under the hood?
Are both the two sensors under the passenger seat both low pressure?
03 9200i AC
Discussion in 'International Forum' started by Pool6710, Nov 2, 2015.
Low pressure reads atleast 110 and the engine fan doesn't turn on. All it blows out is hot air
The fan will cycle and cool the motor down so I know the fan clutch is good. -
Zip tied the fan sensor wire better and the fan kicked on. We'll see if that fixes it tomorrow.
Does the a/c clutch center turn? Does it have power to the a/c clutch? Did a/c season not just go out in Minnesowta? That would be poaching anyways!
A/c will be done by the end of the week here. I like it freezing in my truck. Was a #### hot box today.
Fixed it with some zip ties, I must have a short in a wire. -
Switches on the expansion valve are your low and high pressure switches to run the compressor within safe pressure limits. The switch on the line under the hood is the high pressure switch input to turn on the engine fan when needed.
No. It also depends if your trucks has an APADS module or not, those are different yet again.
I didn't see one located on the firewall, assumed it would be next to the air sensors for buzzer and brake lights?
Usually mounted on firewall on left side near/on air cleaner brackets or coolant reservoir depending on the year.
