03’ 9900 clutch pedal doesn’t return all the way to the top after releasing it.
Discussion in 'International Forum' started by Dadetrucking305, May 24, 2021.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    I’m having to lift it with my toes the rest of the way.How can I fix this?
  3. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Bellcrank is most likely sticking. Disconnect the linkage at the bell crank and check the movement. Also check the return springs on the inside.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Use a small spray of WD-40 with the tube on the end of it, spray where the clutch pedal moves on and ck. spring to see if its still got any pull at end of pedal travel??
    Dadetrucking305 Thanks this.
